Problem comparing 2 different lists
Hello forum!
I have a problem comparing the values of a MultiDropdown with an array of subcategories.
I leave here a image to get more context
So, I have an array of subcategories like this:
        "name": "Subcategory 1",
        "color": "#0CBBAA"
        "name": "Subcategory 2",
        "color": "#0CBBAA"
        "name": "Subcategory 3",
        "color": "#0CBBAA"
And my dropdown receives values in an array like this:
        "subcategories": [
            "value": 1,
            "value": 2,
            "value": 3,
What I need to do is, if a subcategory is selected in the dropdown, filter a list in the repeating group to display items based on the “name” value.
Currently, I’m trying something like this, but I haven’t achieved the desired results, except when I use “:first item.” However, that doesn’t work for me because I need to iterate through all the subcategories.
Screenshot_310
How i can solve this? any examples?
I appreciated constructive replies :smile:
Hey @ignaciocorball1
That’s a tough one. I feel like there is no perfect solution. Maybe try this something like this:
Editor: 805testapp42 | Bubble Editor
Preview: https://805testapp42.bubbleapps.io/version-test/compare_list?debug_mode=true
Screen Recording 2023-05-18 at 3.04.55 PM
Is this what you are looking for? Let me know. :blush:
That is indeed a good solution, @J805, but currently I am working without a bubble database. All endpoint calls are made through the API connector, and data manipulation occurs within the workflow when the button is pressed. :confused:
