Hi guys,
trying to get data from binance through the API connector plugin. I´m getting the JSON response but it´s just appearing as one field to import ![]()
The response doesn´t have the name of the item it is referring to as I´v e seen in other API calls in the tutorials (for example:
“open” : “24”,
“close”:“32”
I imagine the solution has to do with “edit raw data” int he initialize call section. Any pointers on how one would set it up to get it working?
This is the relevant API info from binance´s site:
GET /api/v3/klines
Kline/candlestick bars for a symbol. Klines are uniquely identified by their open time.
Weight: 1
Parameters:
Name Type Mandatory Description
symbol STRING YES
interval ENUM YES
startTime LONG NO
endTime LONG NO
limit INT NO Default 500; max 1000.
If startTime and endTime are not sent, the most recent klines are returned.
Response:
1499040000000, // Open time
“0.01634790”, // Open
“0.80000000”, // High
“0.01575800”, // Low
“0.01577100”, // Close
“148976.11427815”, // Volume
1499644799999, // Close time
“2434.19055334”, // Quote asset volume
308, // Number of trades
“1756.87402397”, // Taker buy base asset volume
“28.46694368”, // Taker buy quote asset volume
“17928899.62484339” // Ignore.
