Problem with a query with x-www-form-urlencoded content-type
I have a request aiming at refreshing an access_token to Revolut API which works well in postman but doesn’t work in bubble.
The post settings for this request are the following:
… and I have a correct answer :
(status code 200
“access_token”: “oa_sand_k1jwhzvj5JohswAnKfNGC6RTkOrRii_s-amMXvYkS3I”,
“token_type”: “bearer”,
“expires_in”: 2399
In bubble, I set the API connector as follows:
… and I have an answer with status code 400 and the following message: {“error”:“invalid_client”,“error_description”:“client_id is missing”}
I also tried the same request with
  • unchecked Querystr. boxes.
  • a form-date body type.
    I however got the same status code and error message.
What should I set the API connector do to make it work?
Your content-type has 2 ‘-’ between www and form. Is that meant to be correct?
Otherwise, i can’t spot any difference between the 2. it says client_id is missing so maybe the param is not being sent somehow
@loh.cher.e have found something interesting. But it may not be enough.
Even if you set this content-type, in some case, Bubble will override this and set it to json.
Here’s how to solve this:
remove parameters
Go in Body
add this:
grant_type=refresh_token&refresh-token=&client_id= and so on will all your parameters
Works with this. Thanks a lot.
