Problem with domain zone with OVH
Hi everyone,
I have a problem setting up my A records in the DNS Zone. I am using OVH.
I’ve been able to add all A records that Bubble was asking me to add. But when I click on “check my settings”, Bubble says that there is one A record that is missing.
This A record doesn’t appear in the list above.
So what I did is that I also added this A record (starting by 213…) in my DNS Zones. But after few days the error message still appears in Bubble.
it has been many days now and I don’t know what to do more. Everything seems to be set up properly.
Thanks in advance for your help,
Hey @alexandre.diroberto,
Can you share what your domain is?
Hey @johnny ,
sure : https://soundmates.fr/
What are all the DNS records Bubble is asking you to add?
These are the ones propagated and I don’t recall the 213 one to be a Bubble IP?
Actually, I take that back, it https://soundmates.fr/ loads for me?
I actually a little hack I always use is just point one CNAME record at the root to app.bubble.io and a CNAME record at www to app.bubble.io and it covers all the needed records and works
Those are the DNS records asked by Bubble :
But 213.186.33.5 is the not found by Bubble.
There is actually a problem for people who wants to join the domain when they use their mobile. In France.
I don’t know if it’s related…
I would like to fix this so I can set up my e-mail.
Thanks,
Ok i’m going to try this
I have this error message when I tried to add the CNAME.
Any clue ?
I’m not too familiar with OVH, but:
It says to remove the A record 213.186.33.5
Oh ok. I removed it then. I will wait to see if it works.
Regarding the CNAME, i’m not sure but does it ask me to remove everything, and then put the CNAME and then put again all DNS records ?
Thanks a lot for your quick help Johnny :smiling_face_with_three_hearts:
Possibly, but I would just try removing that one IP first and see if that fixes the issue.
Have you also considered moving your domain to Cloudflare? I find it’s DNS management so much easier and faster to work with
It worked !!! Thanks a lot.
I just needed to deleted that 213… DNS Record
A huge thank
Awesome!
