Problems Displaying Multiple Selections In RG Filter
Have a RG (Sub-Categories) where a user can select/unselect multiple selections. This works.
Have the workflow setup to add a Current Cell to the custom state using plus or removing a Custom Cell from the Current state, when a Sub-Category is selected or unselected.
This works.
Have a filter setup to filter what’s displayed in a second RG based on the custom state.
When I select the first item in the Sub-Category RG, any items in the second RG are displayed.
But when I select more than one item, only the first item is selected. And if I unselect the first item and still have the second item displayed, the second item gets displayed.
Looking at Element Inspector, I have the custom state set up as:
Not sure how to fix this (but I’m sure it’s an easy fix) :grinning:
And is there a way to see all values in a list custom state after the workflow has finished?
In your Search for Items you are only comparing the first item of the sub-category list. When you add more items you are still only looking at the first item. You need to ask if the Sub-Category is part of the list. Try changing expression to Sub-Category ‘contains’ test’s Sub-Category List.
I tried what you suggested (Sub-Category contains test’s Sub-Category List - but contains isnt in the dropdown after you enter Sub-Category. I was able to get it to work by Sub-Category is in test4’s Sub-Category List. Thanks - you put me on the right track!
Is there a way to see all of the contents of a custom state after a workflow has completed?
You could display the data (state’s list) in a repeating group as the last step in your workflow. You can also find the state of an element in the debugger/inspect.
