[Product Enhancement] Updated Toolbar
That was my first thought as well, but it simply doesn’t behave accordingly. The Deploy button on the slide-out panel does still work that way (see screenshot below) - i.e. it’s disabled when there have been no changes since the last deploy and enabled as soon as a change is made in the editor. The new Deploy button just doesn’t follow that same logic. In fact, I can’t discern any logic to it at all.
I thought maybe the issue checker had something to do with it, but it’s the same behavior whether the issue checker is enabled or not - i.e. predictably unpredictable. :confused:
Well, that’s definitely a strange behavior for the button that should just work in a pretty straightforward way.
If someone from Bubble could provide insight into the logic in a faster manner would be great. Overwise I think you should submit a bug report.
I love it. I think Bubble could also add an option to schedule the publishing of changes. For example, we could make as many modifications as we want, and when clicking to publish, we’d have the option to choose a future date and time for the publication.
Hi! Zoom shortcuts work when the canvas is selected. If you’re still experiencing issues, let us know! Also, stay tuned—we’re working on improvements to the design canvas, including enhanced zoom functionality.
Great callout, Jonathan! You’ll notice this update very soon!
FWIW, this issue appears to have been addressed…sort of. The button is now always visible and its enabled state mimics that of the button on the slide-out panel EXCEPT immediately after a deploy. After a deploy, it remains enabled until the page is refreshed. (Same with other browser tabs for the same app.)
Great :+1:
FYI, the alignment is a bit off.
@alex.bolanos I like the new Toolbar, 40% rollout is good to fix some issues :slight_smile:
Hi everyone, thank you for all the feedback and commentary! We’ve addressed many of the comments shared here, so I hope you’ve noticed that in your day to day building :smile: We will move forward with increasing the rollout to 75% of users before we take it to 100% soon! Keep the feedback coming if you have anything to share :rocket:
A single icon library used across the whole Bubble builder, woah! Not to get too crazy, but maybe next we could standardize the hearer buttons style between side tabs (data has shaded selectors while the rest have underlined)?
In all seriousness, nice job; appreciate the cleanup!
@alex.bolanos, there are a number of issues related to the new menu bar…
  • The hotkey for Copy with workflows doesn’t work. (Nothing gets saved to either the old or new local storage.)
  • The paste hotkey pulls from the old local storage.
  • The contextual (right click) menu lacks the new styling.
I reported the first one, but I don’t have time to submit separate reports for each issue.
EDIT
Just wanted to point out another related issue…
  • Copy to another app does not work properly.
    Choosing EditCopyCopy to another app from the new hierarchical menu stores the data in the old clipboard, but choosing EditPastePaste from the menu pulls the data from the new clipboard. As a result, what gets pasted is unexpected.
Earlier there was a little text showing on top indicating “Saving…”, “Saved”, “Timeout” etc.
Looks like that has gone. Why?
Also, not sure if Edit menu should have been hidden as well.
And definitely not sure if this redesign really solved any important issue.
It’s still there. It was just moved to the right.
I am unable to locate it.
Ah yes indeed, I see now. It does disappear at narrower screen widths - somewhere around 1450 pixels. I guess it’s by design.
Nice work, but…
  1. Undo and Redo need to be present on the toolbar, not in a submenu. Way too many clicks!
  2. The version needs to be in a dropdown, not side pane sliding thing…
You’re viewing it on mobile?
Yes I am
Yeah, that’s what Bubble calls bugs and oversights as.
“By design”
I have got this many times from support: “This is intended behaviour, because it is coded that way i.e. Not a bug because software is working as coded”.
