As shown in the screenshot above, theirs a fiend in each users database called fund, and the function in the screenshot above is meant to get the “Fund” value of the current cell’s creator,
It works before and stopped working when i added a domain name to my app.
i dont know whats wrong, any idea?
Either you’re trying to look at the live version of your app which might have 0 data or you have privacy rules preventing it from being shown.
You can try copying your development data to your live data to troubleshoot. And take a peak at your privacy rules.
all my data are in the live version
does anyone has a solution
Have you checked your User privacy rules?
Or just check in the Debugger… it will show you why the data isn’t showing…
