Repeating group help help
Hello, I need help
I want do this UX/UI into bubble
When user is log i want he see all company link to this account and all legume into the company
:wink:
I have made the first repeating group withoup difficulties but i blocked for the rest
If I understand your question correctly, this is simple to do using nested repeating groups
In other words, have one RG with a content type of Company, which can display all the companies, then within the cell of that RG have another RG, of content type Legume, which can display the current cell’s Company’s legumes (or a search for Legumes relating to the current cell’s company depending on how your datastrcuture is set up).
Sorry I’m french :wink:
It’s not simple for me with RG.
Is it possible to do nested repeating groups ? I think it’s the solution
Yes, as i said, Nested repeating groups is the solution here. You just need to put the second one inside the first one, and relate its data source to the current cell of the first RG.
Ok thanks :wink: I will do that
Euh do you know a tuto for this :wink: ?
@tocabenguillaume
Here is a video around the 14 minute mark where he uses a repeating group inside of a repeating group
@tocabenguillaume l’objectif c’est d’afficher dans la liste, seulement les entreprises qui sont liĂ©es Ă  l’utilisateur (current logged user)?
Hello,
L’objectif est d’afficher toutes les entreprises liĂ©es Ă  l’utilisateur et pour chaque entreprise les lĂ©gumes cultivĂ©s
Je galùre grave là
Dans la BDD
Entreprise = 1 table
Users = 1 table liée à la table entreprise (entreprise est une liste)
Légumes = 1 table liée à la table entreprise (entreprise est une liste)
le problĂšme est que dans la table user entreprise est une liste et je n’arrive pas Ă  splitter les donnĂ©es
@tocabenguillaume
DB:
User:
  • email (text)
  • entreprises (list of Entreprises)
Entreprise:
  • nom (text)
  • lĂ©gumes (list of LĂ©gumes)
Légumes:
  • nom (text)
AprÚs, il faut avoir 2 repeating group (schéma ci-dessous)
Je l’ai testĂ© sur bubble et ça marche de mon cotĂ© !
Merci beaucoup, ça fonctionne :wink:
J’en profite pour poser deux ou trois questions additionnelles pour la suite de mon dev.
J’aimerais que quand je clique sur un lĂ©gume du RG cela m’ouvre une fiche lĂ©gume avec les infos en dynamique en lien avec le lĂ©gume cliquĂ©
Sais tu comment corréler le RG et la fiche légume ?
Dernier point j’aimerais ajouter un bouton “J’ai fait une rĂ©colte” et renseigner le nombre ou les kilos de lĂ©gumes cueillis. ça je sais faire mais comment le gĂ©rerais tu dans la base de donnĂ©es ?
@tocabenguillaume est-ce que tu peux cliquer sur le bouton “SOLUTION”, pour que ma rĂ©ponse soit rĂ©fĂ©rencĂ©e ?
Pour la 2Ăšme question, oui c’est possible de corrĂ©ler le RG et la fiche lĂ©gume:
  • si la “fiche lĂ©gume” est un pop-up, il faut utiliser “display data in group/pop-up” et envoyer comme source “current cell’s Legume”
  • si la “fiche lĂ©gume” est une page, il faut utiliser “go to page” (cibler la page “legume”) et envoyer comme donnĂ©e “current cell’s Legume”, mais il ne faut pas oublier de configurer la page cible [type of data = “Legume”]
Si tu as d’autres questions ou problùmes concernant ton projet, je propose des sessions de mentoring pour Bubble ? Tu peux m’envoyer un mail: notpaperbased@gmail.com
Done :wink:
