Hi All,
I have a repeating group that used the value from the dropdown above to populate the data within.
When first loaded, the dropdown value is populated with values. The group that that the repeating group is in is shown based on the menu item that a user clicks.
The repeating group will not show the data until a user manually chooses another option in the dropdown and then reselects the 1st item in the dropdown.
Is there a way to avoid this and have the data load without having to refresh the dropdown value manually (currently set with a default value of the 1st item)?
Thanks, appreciated.
Robert
