Responsive design issues - Padding seems to not be recognized
Hi all,
I am following along on YouTube with Gregory John and the new course that he is putting out now for Bubble.io. But I’m having an issue with the responsive design that I feel should not be an issue.
I have followed along with what he has done and to get a bit of space around the text when on a screen of 768 (as Gregory did) I set 32px left right padding on the group section (which is the first container in the elements tree), however when I go back to the responsive tab I can see the padding there on Group Section but when I move down to 768 the “group content” container that hold the text does not react to the padding and behaves like its not there. I can see the group content overlaying the padding. What could be a possible reason and/or solution for this?
( FYI, I am on the free version of bubble while I learn however I googled if that would effect it and apparently Responsive design is still effective on the free version.)
Regards Sii
Panic is off peeps… So after some extra deep searching I realized that I had the group content element accidently set to a fixed width of 768… My mistake! So the issue is Solved
Good to see you figured it out.
For future reference, you can also compare your editor with the YouTube course’s editor: bc-workplace-demo | Bubble Editor
Awesome… Thanks for the tip. I will check that out for sure Armand. :slight_smile: Edit: Yes the Follow along demo app… I guess I just forgot that I had set the 768 width and then overlooked it. Thanks again
