Do you mean for the backend workflow? Am I able to save something to a state from the backend workflow? If so, how will I be able to resue the workflow for other pages, states…etc?
no need to backend workflow at all, you can just set create custom state same as the parameters you’ve already in the backend workflow and you pass the values to the custom state the same way you are passing it now to the backend workflow.
It’s the same process but you can just do it on the client side quickly with custom states or custom groups to hold the dynamic text
