I have sendgrid email with a sender authorisation is verified. when i am testing using postman implementation parameters with bearer and body beautify, i keep facing denied message.
What do your headers look like?
You should have an Authorization header with the value as Bearer <API Key>.
https://docs.sendgrid.com/api-reference/how-to-use-the-sendgrid-v3-api/authentication
@blurapps
What do you think about the installation?
Anyone?
These go in your header typically, they usually aren’t sent at query string parameters
Can you please explain your point?
Interesting, I will check out and get back to you quickly!
Invalid
Can you show your headers and click view in console?
Solved by adding token key API
