πŸ’₯ Shadow Caster - Pro shadows for images & text
Hi Bubble :raised_hand:
I’m very excited to show you a new plugin that can change a lot in your next app release :wink:
Is as simple as install plugin, define a shadow schema, and use it to elements :slight_smile:
Please follow for a detailed view DEMO page, Plugin page.
A lot of pictures with examples below:
A tiny blue shadow for text without offset
PNG images can also drop a shadow from now
Screenshot_2
Screenshot_3
Looks natural
Screenshot_4
Screenshot_5
A tiny offset shadow
Screenshot_6
Screenshot_7
A glow effect is possible too :slight_smile:
Screenshot_8
Screenshot_9
If you enjoyed until here, then leave a like, it’s a nice support to do things and bring bubble community new features :wink:
DEMO page,
Plugin page,
Author,
Contact me
Mr. Bubbles
Works also for SVG, and Lottie Animations :slight_smile:
Looks great you guys good work!
@bubbleis love this plugin thanks for making it! Is there custom CSS or another way to set the bottom shadow to 0?
The image is a background image so that may be why the shadow is extending outside of the group? I’ve got the ID attribute on the group containing the background image because I’m not seeing a way to set the ID attribute to the dynamic background image.
