Into the workflow, parameters don’t show up.
It’s a bug? Anything to change?
Hi jnornella,
We’re facing the same issue. Parameters like numbers, date and more are not showing up in the workflow - hence not possible to connect them to any fields.
“text” parameters are the only ones showing for us.
No idea how to fix this currently, and its a major issue.
Following.
