SQL Connector bubble - how call insert into querries inside workflow
Hi
I try using sql connector database
When i insert data to mysql and want get his new id ( and be sure to other user not add new other record and i get wrong number). I wanted use for this mysql transaction like below, who work in my mysql database
START TRANSACTION;
INSERT INTO lightlog_gmp.Przeplywy
(Id, CzekaNaReakcje, DataWniosku, Uwagi, StatusPrzeplywu_Id, Proces_Id, OdKogo_Id, DoKogo_Id)
VALUES
(null, ?, ?, ?, ?, ?, ?, ?);
SELECT LAST_INSERT_ID();
COMMIT;
but i received error like this
SQL Database Connector issue: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'INSERT INTO lightlog_gmp.Przeplywy
(Id, CzekaNaReakcje, DataWniosku, Uwagi, ’ at line 2
Do you have any idea for other solutions for this problem?
screens
Are you sure that’s correct syntax for MySQL? Also, I’m pretty sure you can only do one transaction, but you have multiple. Try a single one and see what happens.
Thanks for answer
Yeah you have right, I edit my post and add screens.
and I test this at mysql workbench and … work - i added screen
I am not sure - what do you think when you write “multiply transaction?” I want be sure other user cannot add next record and return me wrong number
So here is one of my smallest queries, but it shows you how to use the variables. First, I don’t see you using the variables. Secondly it’s telling you that it doesn’t like the second line (probably) because you have the ; which ends your query. It might not have been built for something like this, I am not sure?
As a alternate way of doing what you want, create another column in your database and insert a unique value for each transaction, then in a second transaction…
select id in xyz
where uniquevalue=abc123;
When I use $1, $2 etc.
which is not existed when I use sign ? - i don’t know why, but first ‘?’ is recognise as first parameter, second ‘?’ is second parameter- i checked that only at mysql. Maybe this is only except only for mysql…
https://www.youtube.com/watch?v=iN34KFben7Q 13:13 portugal guy from this yt film show how he parsed argument in query for mysql in bubble sql connector
Send a pic. And yes you might need the ? For MySQL, not sure exactly.
I explained this here: SQL Connector SQL Server Parameter Format - #2 by ben13
thanks a lot :wink: , so are you using mysql as your database? How you convert tinyint (boolean at mysql) to bubble yes/no? I try a few times, and every time bubble cannot understand change 1 to yes and 0 to no
How about you keep it the same and just build logic around 0 and 1
im having the same problem
what is the correct syntax
I’m not entirely sure, but I don’t think the SQL Connector supports a block of statements. I think it might only work for one select, insert, update, etc. at a time. One idea is to convert your code into a MySQL Stored Procedure and then call the Stored Procedure from Bubble passing it the input parameters. I call MySQL Stored Procedures from my app and I know it works. Also, if you want the LAST_INSERT_ID to be available in your Bubble app you’d need to put that in a separate SQL Connector query and call it in the next workflow activity.
Also, confirming you use “?” for MySQL input parameters.
Joey
