Hello, Bubblers!
I’m testing a new app and couldn’t get around this issue. I have a group with a few elements inside a popup and I need the group to always be at the bottom of the popup.}
I’ve tried to use “floating groups” but since the group is relative to the page, not the element, I’m not able to insert it inside the popup.
Is there a way to do this?
Thanks for the help!
@thiagovaz11011 welcome to the community!
Build a structure like this:
Let’s say your popup is 600 px high and the width does not matter for this example
Place on 400px high group starting at height 0px
Place a 200px high group at height 400px
Now click on both keeping the control key pressed, then right-click and choose group elements in a group (or something along these lines). This will create a parent group for both of our groups. This master group should have a height of 600px which is the total height of the popup
Your second 200px group should now be placed at the bottom of the popup
Perfect! Thanks for the solution!
