Stripe.js "Unknown Paramater" Error for every POST method
Several days ago, every Stripe.js method worked perfectly, but now I get an error every time I try to log data for a Custom Seller. Whenever I use methods like “Create a Custom Seller”, “Update a Custom Seller’s DOB”, “Update a Custom Seller’s Address”, etc. I get the following error:
Raw error:{
“error”: {
“code”: “parameter_unknown”,
“doc_url”: “https://stripe.com/docs/error-codes/parameter-unknown”,
“message”: “Received unknown parameter: legal_entity”,
“param”: “legal_entity”,
“type”: “invalid_request_error”
Any thoughts? I’d greatly appreciate any help.
@copilot
What version are you running?
If it suddenly stopped working without you doing anything, might be on @copilot’s side I think they use an internal API for Stripe.js.
I’m using 1.8.10, the last version before the Beta.
I submitted a bug report – I just didn’t know if it was something I was specifically doing incorrectly.
My best guess would be that Stripe did away with the “legal_entity” umbrella, but Copilot hasn’t taken it out of their JSON requests.
I can’t find the legal_entity parameter in Stripe. I think it’s called verification now. Check this topic https://github.com/stripe/stripe-android/issues/821
    "verification": {
      "details": "Provided identity information could not be verified",
      "details_code": "failed_keyed_identity",
      "document": {
        "back": null,
        "details": null,
        "details_code": null,
        "front": null
      "status": "unverified"
Alright, I may need to rig a barebones Stripe API with API Connector until Copilot can get this fixed.
I think I’ve found the problem. Stripe seems to have totally done away with the “legal_entity” branch for Custom Sellers. Instead, you can either set up a seller account as an individual – in which all the verification information is stored in the “individual” sub-branch – or as a company, in which you create multiple “persons” connected with that account (all of whom need to be verified).
@lharrod1 Stripe API updates page shows changes to legal_entity. We are reviewing a few items with @copilot before their upcoming plugin update.
Started seeing similar issue for
https://stripe.com/docs/api/webhook_endpoints/create
but nothing interesting found in API updates page
