Hello,
I have been looking for help with achieving the attached tabbed view for a group control. I can’t find any element similar to this. What is the best way to get this result?
Thanks in advance
A tabbed view is pretty much the same as a horizontal menu bar. You are effectively loading each tab or page as a group and hiding all except one on page load. you can do it as a list or you can create it manually depending on how your web app works. There will be some logic on the tabs (buttons) which closes an visible tabs (groups) and display the one you have clicked on, and also change the color of the tab (button)
Thank you, will check this approach
