Is there a way to make this button change and keep a certain color when clicked. For example, when you click it, it turns from white and to green and stays green until another button is clicked? If show, how? And how would I set it to turn back to white when another button is clicked?
Thanks
Hey,
You would use a conditional and a state. I would highly suggest checking out this udemy course. It will tell you everything you need to give you solid basics.
