Hi all!
I run www.radabard.com which I built using bubble.io. I am trying to fix a minor formatting error on mobile, where some bulleted lists do not respond to font / font size settings (they do still respond to settings like bold, italics, etc.). This ONLY happens on mobile and updates as soon as I try to open/collapse any section on the page, but I need it to respond from the get-go.
The bulleted list is a repeatable object that is referenced in multiple places, and yet only in some places it responds while in others it does not. There is nothing overwriting its settings or doing anything that could cause this, each instance is called identically and has identical properties in the editor.
Been working on finding what the difference is for several days now and I am confident there is none, so I am wondering if maybe style options just start to break down once there are too many nested groups / repeating groups? Is this a known issue?
