Tool Tips Speed
Hi everyone,
quick questions!
I find that the tool tip appears to slowly, is it possible to speed this up so the tool tips show up quicker when hovering over something?
Please pick a subcategory to help organize the information. Thanks!
Also, the more context you provide with your questions (screenshots, link to an open app, etc.), the more likely you’ll get good help quickly :slight_smile:
What tooltip are you talking about?
Hey :wave: @johnny I think they mean this one:
@bentomsouthgate, I don’t know of a way to speed it up, maybe someone else knows something I don’t. You could create your own using a floating group for certain things though. That might help.
Or you can try one of these plugins, they might be faster.
Tooltips
or this one
Tooltips BDK
Hope that helps! :blush:
@j805 www.NoCodeMinute.com
  • One-on-One Tutoring
  • eLearning Hub
  • Video Tutorials
  • No-Code Classes
@J805 yes that’s the one I am on about.
Thanks, I will try those plugins!
No problem. :blush:
