Trouble with Lists. Maybe you can help
When adding a Cast/Crew to a Film, you have to “Make Changes To The Film” as well. This means adding the Cast/Crew you just created to the Film’s List of Cast/Crew.
Looking at the workflow, when the user fills out the Cast and Crew form and hits save. I can make it save to the CastCrew Data Type. I can also add that data types ID to all films which then works on the front end.
The problem is it adds that Cast member to ALL films.
What i need is that “List to Change” to also include “Current Page Films”.
Bubble won’t let me do that.
You’re not changing a list of Films, you’re just changing one Film. So you should use the “Make Change a thing” action, not “Make changes to a list.”
Thats it!
Oh man thank you thank you thank you @andrewgassen and @dbevan !!
