Two groups on eachother Hide/show problem
Hi Bubblers!
I have two groups and I have created a simple workflow for them, i.e show one group when this button clicks and hide the other group, but it only hides the group not shows anything.
The index is fixed so are the groups. So please help me to solve this problem.
Regards ;
Saad Nawaz :slight_smile:
Make one group invisible by default and set a conditional statement for it to become visible only when the other group is invisible. Then build a workflow to make the other group visible or invisible when you click the button.
PS. It would be helpful if you could attach some screenshots of your elements and workflows.
