Using a dropdown and Search&Autocorrect to display data
Hi. I hope someone can help me with this. It seems like it should be an easy setup but I have not been successful with it yet. I have a page with repeating group data that references a dropdown (as a filter) and an input box attached to ZeroQode’s Search&Autocorrect plugin.
The repeating group is currently set up with conditions where if you select an item from the dropdown, only those records are pulled and if you type in the input only records that match the typing are pulled. They’re very straightforward conditions “if dropdown is not empty, data source is [whatever the source] with constraints on the field with the dropdown” and “if the input value’s not empty, the data source is the search&autocorrect’s matches”. It works just fine.
Here’s my problem: I’d like to set up a condition where if both the dropdown and input fields are not empty, the data source pulls records that contain both the dropdown choice and the input field text. For some reason, I can’t seem to make this work. The data source for search&autocorrect is a different one from just setting up a search and using a constraint for the dropdown category. Does anyone have experience with this and know how I might fix it?
Thanks.
Have you tried the “Merged with” function?
Thanks for thinking about that. It almost worked. It’s functioning now more like an “or” operator rather than and “and”. What I want to achieve is essentially a double filter when the input (part of the search&autocorrect) has data in it, all records are pulled for that, but when the category dropdown box is also selected, it filters those data again and only shows data that match both the input and the dropdown. Using merge with pulls both types of records rather than filtering them. Does that make sense?
OK, building on that I’ve figured it out. If you set a condition on your repeating group where both the input value and dropdown are not empty, set the data source to your search&autocorrects matches and use :filter to filter out by category. It works! Thanks for the idea.
