Using a Jquery "plugin" inside of Bubble
Hi, is it possible to use a Jquery plugin inside of Bubble without making a "plugin’?
I’ve found this https://github.com/musclesoft/jquery-connections/wiki plugin which looks like the perfect MVP for something I’m working on and just want to get it to work between two or more elements. The only thing I can seem to find is to create it as a plugin, but being a newbie I’m a little hesitant, although willing to give it a try. I just want to be sure first I’m not overlooking something.
Thanks in advance for any help.
Did you ever find a way to use it without creating a plugin? I’m facing a similar issue.
HI Salvador08, no, i’m afraid not. Something i’ve got on my ever expanding to do list is to seek how to do this.
