Using custom code on bubble
Hey team,
I have come across a situation where I might need to use a tool that has been created using Python code. I noticed that bubble mentions that you can use custom code but is it possible to use Python? If so, how would I be able to put it in my web app?
Kind regards
Hi @thepiggyprojectnz
Yes you can use custom code in Bubble but only if it’s javascript.
In your case, you can host your python code on a server and make you python tool communicate with Bubble using custom API calls to your server.
