Using MailerSend for transactional emails
Is there anyone out there who has successfully set up MailerSend with their Bubble app using the API connector? And is willing to share/help with the correct settings?
Can’t find even a single mention of MailerSend anywhere on the forum!!!
Hello! :wave:
Yes, we can guide you with connecting MailerSend using the API connector.
Once you’ve added the API name, you need to set the Authentication to “None or self-handled” and then add the following shared headers:
Key: Authorization
Value: Bearer {Your MailerSend API Token}
Key: Content-Type
Value: application/json
Key: X-Requested-With
Value: XMLHttpRequest
If you’re adding a call to send an email, make sure you select the Data type as “Empty” otherwise you won’t be able to initialize the call.
We hope this helps!
For anyone still struggling, these videos where helpful:
Part 1 - Mailersend Bubble Transaction Emails - Part 1 - YouTube
Part 2 - Mailersend / Bubble Transaction Emails - Part 2 - YouTube
@MailerSend can you assist. I’m seeing this error:
This is my body script:
    "from": {
      "email": "team@tracksmallwins.com",
      "name": "TrackSmallWins.com"
    "to": [
        "email": "<toemail>"      }
    "subject": "<subject>",
    "html": "<body>,
"template_id": "xxxxxx"
Hi @mayur,
You’re simply missing a quote (") at the end of <body>
Your code should look like the following instead:
    "from": {
    "to": [
    "html": "<body>",
Ah!! Such a simple thing
By the way, for anyone watching this thread… here is the API JSON call that ended up working for me so far…
    "from": {
    "to": [
        "email": "<toemail>",
        "name": "<toname>"
    "html": "<emailbody>",
	"template_id": "xxxxxxxxx",
    "variables": [
        "substitutions": [
            "var": "body",
            "value": "<emailbody>"
Following up on this for anyone looking for answers, Neils videos mentioned above were very helpful. I can now get the API call to work fine and I can send test emails now from the API settings.
Transactional emails inside my app don’t work though. I’m asking @neilpierce for some assistance to see if he spots the issue.
Here is the video I sent Neil:
Also, look at your server logs to see if the email is being formatted properly:
I will update this thread once I have some answers
This should fix you up.
Thanks @neilpierce for looking into it. That was it! I would never have figured it out.
Recording a video here for anyone else trying to figure this out:
