good I’m agree with you
The warnings about that are just warnings. They don’t inhibit you in any other way, do they? Just ignore them. (This new “feature” isn’t helpful and I trust it will go away once Bubble understands how useless it is. But until then, just ignore it. If they should never remove it, well, just ignore it.)
Any luck anyone? This bug is completely breaking my app which has a Twitter style feed.
The name and handles of countless profiles has become blank, and all that’s left is a floating profile picture.
I could make a handful of warnings disappear by cleaning the [click], same here. Except one that I still don’t understand. It’s not blocking though
Solved my problema tks
Update: I’m getting this error on text elements that have images inside of them. Images were attached using the rich text editor.
However, not all text elements with images have this issue, just most which is still pretty signifigant.
