It will be compatible with Solana soon
Update v.1.1
- Fixed Torus wallet
- Self-custodial wallet now works too
Thanks for the update. We can sign transactions, is it possible to send them to the blockchain directly too ? I donât see the correpsonding action in the plugin
Do you mean âSend Transactionâ feature? Usually to send to blockchain you need to interact with some form of smart contract.
FYI: If you will connect with metamask, this plugin can be combined with Web3 & Metamask plugin.
Yes Yes, I mean a âsend transactionâ feature (as the one that can be found in the Web3 and Metamask plugin" ). Letâs say I want to send a transaction to a smart contract using web3auth (and Google as preferred auth platform), can I do it using your plugin or do I need t use a webjs plugin additionnaly ? And is this Web3 & Metamask plugin compatible with the web3auth web2 login ?
Thanks so much for your help
I will push an update soon that will make it compatible, so you will be able to do any transactions and interactions with smart contract.
Use Sign feature, the signature can be used as password ![]()
But make sure the data for signing wonât change, changing any character in it will result in different signature.
