I’m not really a tech person. As title says… I don’t know what’s wrong. I’ve tried switching between “Run” and “Step by step” also but it doesn’t even do anything, just freezes the same. Anything that I click on starts loading infinitely, just ends hanging basically. I can’t even click one button. It’s now been some days and truly I don’t remember changing anything specific before it happened that’s out of the normal editing UI/workflows… I really need to fix some issues going on for my users but not being able to run the test version with the debugger on is hurting me a lot since inspecting elemens is really important for me to fix problems. Anyone know what could be happening?
I tried searching the forums but found nothing… In the picture you can see the loading bar at the top. This is what happens each time I try to click anything, absolutely anything. Nothing works at all, even the debugger options. Alternating between “Normal”, “Slow”, and “Step by step” doesn’t trigger anything . The only thing that ever happens is the infinite loading bar…
UPDATED WITH IMAGES:
Clicked on variety of buttons, all generate the same response:
If you let it go for unlimited time, it just reaches the end but never actually does anything and stays “loading”. Happens with anything you click. the regular www.website.com/version-test without the debugger on works perfectly fine… also forgot to add, inspecting on the currently visible elements works well, but since nothing works it’s all I can reach to inspect… any pointers would mean a lot
Maybe you can show us a video of what is going on? That might help us troubleshoot the issue.
