I have tried uploading videos to karaoke.bubbleapps.io and recording videos but when i play them the audio dosne twork
I am Bane from Ziggeo support. I just wanted to check with you if you had by any chance sent us an email?
It would help us to see the videos directly - without you revealing them in the public forum. Email is support@ziggeo.com. Of course, if you are OK with it, it is OK with us if you were to post info about them here as well
I presume that you are using Bubble.is plugin for our system, or are you adding the code into your app? It should not make any difference, however plugin is using stable revision, so knowing that helps.
Regards,
Bane
