403 Forbidden error with GoDaddy domain, Not Secure connection
Hi everyone,
I’m getting 403 error from Cloudflare. Connection shows up as not secure:
The settings page shows the domain is configured correctly:
I do not have CAA DNS record, Google Dig outputs the following for the domain:
id 55043
opcode QUERY
rcode NOERROR
flags QR RD RA
;QUESTION
allthingsbonding.com. IN CAA
;ANSWER
;AUTHORITY
allthingsbonding.com. 599 IN SOA ns21.domaincontrol.com. dns.jomax.net. 2020101405 28800 7200 604800 600
;ADDITIONAL
Please help.
Did you just set it up? Because mine took 24 hours before it started working correctly. I’m assuming it was GoDaddy’s DNS configuration that took a minute to update.
Yes, I just set it up. Thanks for letting me know. Probably Bubble should have a warning about such a possible delay :slight_smile:
I’ll update tomorrow then about whether this is solved.
Ok, tomorrow is now, and it works without further input from me :slight_smile:
