I’m working on a store that sells goods, the purpose of this webapp is to allow customers to buy the goods and even make a subscription to products that allows that. This is a great example of what I’m trying to do: https://shop.smallpetselect.com/products/2nd-cutting-timothy-hay
You should be able to add normal one time purchase products and subscription products that will charge for each delivery.
I have tried to implement that into stripe but the plugin does not allow for a cart experience the case were I want to add multi type products (subscriptions and products), so I wanted to implement that in the backend of bubble by using the charge a saved cc. Unless there is actually a way to do this with stripe, how reliable do you think bubble is with this task? Cuz this is definitely a delicate part that I can’t mess.
