I have a Repeating group sandwiched between two floating groups, and would like to enable both horizontal and vertical scrolling on the repeating group, without affecting the floating groups on either side. The RG has up to 30 columns, so I can’t just change the page size.
I’ve seen a solution where you nest a repeating group in another repeating group
This unfortuanetly means you have to scroll individual rows, I’d like to scroll all the rows at once as well as the headers.
Do you have a screenshot or a gif to explain this better?
If Trello works according to your requirement, you can create a horizontal scrolling repeating group and put a vertical scrolling repeating inside the cell of the horizontal RG.
