Hi!
I’m struggling with something “simple”: I can animate text/icon elements on hover (using e.g. the plugin “Animate Font Awesome”), but when those elements are inside a repeating group, I cannot do it. I’ve also tried with “Do when condition is true”, but the elements inside a repeating group are not selectable inside a workflow… The effect I’m looking for is basically zooming (making bigger) a result inside a repeating group (equivalent to what Netflix does). Any idea on how to do this? Thanks a lot!
use boolean value states on the repeating group, thats the only way to parse the data sometimes.
Thanks, @max79268! I will give a try
mood
