Are their more advanced options for the design?
I’d like to use photoshop but how do I convert the UI into actual buttons? What are the options? Thanks!
Daine
Hey @daine - can you post a few picture examples of what you’re looking to replicate? Within Bubble, you can stylize things to a pretty good extent by removing the pre-set style from an element and then customizing it.
You can apply low-level transformations within Bubble (ex. using a gradient), which is what I would suggest. However, if you create an image in Photoshop, you can set the “background style” to an Image (or series of images if you want conditional states to apply) and use what you created in Photoshop.
You can’t “import” designs from other tools, everything has to be made natively in Bubble. You can use Photoshop or Sketch or Figma or whatever tool you’d like to make assets, but you can’t import a file and turn your mockups into a Bubble app.
