<Design> How bubblers design professionally? Sketch? PSD? I have no clue
I don’t know anything about web design.
Airdev Canvas, or Google materials can be used.
How do you design you app?
Hi, if you’re asking about how you design an app in Bubble I think personally for most projects you don’t need any external tool. Bubble is so easy to manipulate that you can prototype as you go and see what fits best.
With that said, you can absolutely sketch your website first and for that purpose I think Sketch does a really good job.
Nice Bubbling! :smiley:
Thanks for your kind response :smile: beginner’s another question:
If I import designs by Sketch into Bubble is it in Image type?
If there’s buttons then what do I have to do to make it work?
What happens to responsiveness when we import the design?
Thank you,
Try using Adobe XD. It’s free and you can test it on mobile and add interactions, animations and flows.
Sketch for me is too static, you would need Invision and other tools. It gets messy. With Adobe XD its just one clean professional tool for free.
Regards
PS. I’ve been a Product Designer for more that 20 years, I’ve used tools like Sketch, Figma, Uxpin and others and the best way for you to find out is to just start playing around with them. Different tools are good for different levels.
Thanks so much! I’ll go play around with them, THANKS :smiling_face_with_three_hearts:
