Just bought your plugin and testing it out now, great! One question, is there a way to add a countdown? I’m asking because I see a countdown label on your plugin’s website. If not, I’ll try another way.
@lindsay_knowcode I figured it out by adding a text field and insert the plugin’s countdown seconds ad dynamic data.
There should be two countdown exposed states …
mm:ss
I’ll double check in the morning - thanks for letting me know.
@lindsay_knowcode Yes, you are right, no need to double check haha. Thanks!
