In my bubble app everything was working fine but suddenly backend workflows stopped working. Like If i Create a new API workflow and schedule it to create a new thing the API workflow will run but none of the actions inside workflow will run. I tried adding and removing privacy rules as well but the workflow actions not running at all for all the workflows in backend throughout the app felt weird.
I’d also like to mention that when I check Server Logs I don’t see backend workflow actions running at all. Like I see that the API workflow runs but not the actions. If the conditions did not meet or for any reason there was an issue with running action it generally shows action failed but it shows none of it for many API workflows set up that were previously working and none of them were touched
Please see below video and help me with this
Go to Scheduler from Logs and Press Resume Tasks
Also, avoid posting videos publicly with your editor URL in view, it is a security issue potentially
Thanks @boston85719
It’s solved!
