Best way to save posts (or products etc) per user
I have a specific question but think this will be broadly useful for anyone saving multiple ‘things’ that are related to a specific user in their application so hopefully this will help others!
I have a site that allows a specific user to save their favourite ‘posts’.
My question is what is the most optimal (performance) way to save this data in Bubble.
I’ve had a look at some SQL database design tutorials etc so was thinking of :
  • Each post has a unique ID in a “Post” data type which also includes the content of the post.
  • Add a ‘posts’ field to my “User” data type which is a list of unique ID’s of posts
  • When querying and returning the records, I would query “give me all the current users saved posts” - which would be the list of unique ID’s in the User data table, and then it would look those ID’s up in the Posts table?
  • Is this optimal or is there a better way to do it?
Hi there, @nick14… what you described (linking two custom data types together by having a field in one of the data types that references the other data type) is “basic” Bubble functionality that you should definitely take advantage of. In your example, having a posts field on the User data type that is a list of posts a user has saved is a reasonable way to go. When you need to access a user’s saved posts, the expression Current user's posts will do the trick.
Something to keep in mind, though, is that if a user might save hundreds or thousands of posts (which would make the list in their posts field quite long), you might be better off from a performance perspective if you use a custom data type to store the association between a user and each of their saved posts. You can do some searching for information on this topic, but a search through a custom data type can often be more performant than accessing a long list on another data type.
Hope this helps.
Best…
Mike
