Building a Messaging System
What is an API I could use for a messaging system that I need for my app? I need a section in my app with conversations such as you would see in Facebook or whatsapp. Thank you!
You can build it in your Bubble app if you’d like - no need for a 3rd party.
This widget by Airdev could be helpful. You can view the editor and see how they built it. You can copy it and just tweak it a bit to suit your requirements.
Hope it helps.
Disqus plugin for quick and easy install.
Thank you bless up
