Conditional data source problem using Fuzzy Search & Autocorrect
i had to set these two values. they must be new from the last time you updated.
selected timeframe will expose the start/end time (and applicable resource) from when you are clicking and dragging to create an event on the calendar
here’s what those expose
Screen Shot 2021-08-09 at 9.03.38 PM
Screen Shot 2021-08-09 at 9.03.28 PM
Many thanks :slight_smile:
I’ll work through the others … just having lunch.
no worries! let me know if you’re still having issues after fixing those errors in red! :raised_hands:
Hi Jared
I’ve fixed all but 2 issues (see below).
They change from red to blue but the issues persist.
Can you please advise me how to fix this.
Many thanks!
mine look like this and i see 7 total errors. odd we dont see the same
it’s odd because they were’nt breaking changes.
I think this is what you’re going for here
Screen Shot 2021-08-09 at 9.47.08 PM
they were’nt supposed to be but you’re version was so far back that they were
Yes. I now see 6 errors as well. Must have been lagging.
I’ll have as shot at fixing them and let you know if I get stuck.
should be quick. you just need to replace where you were getting info from before.
this may be helpful as you do this
That is very useful. I saw it a while back but forgot about it.
No more errors but I’ll have to do some testing.
Many thanks indeed :slight_smile:
It still freezes - unresponsive. Any ideas?
The list carries on but this is the start.
Ok. Give me a few
@marksrunge, my suggestion here will be to first check out this page and it’s editor
the issue must lie with the mixture of plugins you are using on this page as I hinted at above.
I have copied your setup into a page of it’s own and have no issues.
for whatever reason, one of the other date manipulating plugins you are using is messing things up and blocking moment.js from loading correctly. if you can figure it out, perhaps I can create an equivalent in my plugin so that you can get rid of the stuff that’s messing things up!
I’d start by adding things to the test page I created until it breaks. One at a time. I can help push a fix, perhaps, with that info
unfortunately, bubble doesn’t make it easy for us to know what libraries others are using. one thought i have is to replace the date/time pickers with mine unless they are already. you’ll notice i cloned the air date/time picker into my plugin so i could block the moment library it was calling and have it rely on the one i want to load
I’ll experiment a bit. I suspect the air date picker.
So I made a backup and removed all air date time pickers and just removed where they were referenced. I was hoping that by removing them the calendar would work but it still doesn’t so my guess was wrong.
Bummer. I’d follow my previous suggestion to only add back in the elements that manipúlate. Don’t waste time recreating the whole page unless you have to. Just stage them to the screen and make sure they’re active.
I’ll do my best but not sure what you mean by add back in elements that manipulate?
FYI, there are no errors now and the debug console show just three errors and not the long list that was happening earlier.
Also, FYI.
Hi Jared. Just so I can make progress, I’ll revert to a backup and downgrade the plugin to the one that works for me.
I’ll just have to come back to this issue once the project is live because my partner is becoming frustrated and doesn’t understand.
