Hi I recently tried to create a level system for my application . The idea was to create different options sets with 100 levels
ex : level 1 : xp max = 100
and each time the user reach his current max xp , the user level uprades ex : level 2 : xp max 200 until reaching the 100th level . I did not want to do 100 workflows so I tried to make an API Workflow on list but it doesnt work . If you have a better solution please suggest ! Thanks for your help
I made this a long time ago, maybe this is what you are looking for: Bubble | No-code apps Editor: tylerboodman-test-app | Bubble Editor
It’s based off of some formula where a higher level requires a certain amount more XP than the last level.
Looking this over, i think it needs to be cleaned up. I don’t like the “Do every 2 seconds” event being there
Okay I tweaked it a little bit, but I removed the fun “Level up” popup for now. Really the Level field isn’t needed cause you could sort users by their exact XP number and calculate it on screen but ![]()
Thanks a lot but I have some questions how did you make changes to the current user level tier or class ? Cause I cannot figure out how you did it , and last triggering a pop up for the level up how make it happen ?
I’m actually not setting the User’s tier/class, just that group searches for the tier with the user’s level. I suppose you could set the User’s tier at the same time as the XP and Level but even the Level is redundant, I kind of like the idea of just storing XP and thats it
I think the scaling needs to be more modular, right now I have a lot of hardcoded numbers.
The popup let me check the app again how that can be done.
Okay check it now, it checks if the new level is higher than the previous and animates it for a second ![]()
Maybe all those numbers like 0.5, 0.1, etc could be put in option set attributes, then everything references that
Okay I got rid of the Level field so everything relies on XP field
I would turn on parenthesis, I don’t trust Bubble’s order of operations without seeing it for myself
Notice on mine there’s parenthesis App Settings → Versions tab → Beta Features at the bottom
OMG ! It worked thank you
