Hey!
I have a text box that I want to show to a user that matches condition xyz A or condition xyz B.
In the text box “conditions” tab, I can define multiple conditions.
For example, if user:
Is logged in
Is of age 18+
and
Referred a friend
→ text box is visible
OR
User is
logged in
and
User is 65+
→ Text box is visible
Would that work or they will interfere with each other due to overlapping conditions and I need to have 2 different elements?
Thank you,
The conditions on an element go in order so you can just change the order of them if the behavior is not what you’re looking for!
Kevin
Free no-code bootcamp by Airdev
So having multiple “define another condition” acts as an “or”?
It acts as an AND unless there is a conflict with another condition, in which case it gets trumped. You can also define your conditions to not have conflicts, or play around with it as you like!
Kevin
system
Closed
June 15, 2022, 3:01am
5
