I am creating an app where in I let the users create a post and then show the post in a repeating group. But I want to display the post in a group and not a repeating group.
Basically I want my app to create a group and display the data whenever usre post something. How should I go about it ?
Please help
@NigelG
@cakeheke
@emmanuel
Did you watch the video ‘send data to a group’?
yes. Well here is my workflow
But now when I am trying to show the data in the group it does not appear over there. However when I do the same with repeating group the input starts to show. Where am I wrong
With the repeating group, you put the following…
Make sure you put the same thing in with the normal group.
I have the same problem. I think here you have to work with “display data” and parent groups text workflow
You need to send the repeating group thing to the group as part of the workflow.
