My replies about the body field must be invisible.
Yeah, I have set it to Text also… from the beginning. Your solution works, Thanks @mikeloc
Still I dont know guys why it should be Option Set when I add entries to the database?
@mikeloc shadowbanned himself by accident
still learning his mod powers
Careful, @tylerboodman… I’ve got an itchy trigger finger after the past 7+ days, which I have hated every single minute of, by the way.
Quite the contrary…
…with a Text you’ll have to use filters every time you want to match the value to an option set… which 1. rather defeats the purpose of using an option set (maybe not entirely, but to a point), and 2. just adds extra unnecessary steps every single time you need to refer to an Option.
Well… it doesn’t have to be… but what’s the point of using an Option Set if you’re just going to save things as text values? (there definitely are some use cases for that, but this isn’t one of them as far as I can see).
But as, I said, if it works for you to use texts instead of Option Sets (and it makes sense to you, and you don’t mind the extra complications), then stick with it.
I’ll try to do as you suggested. I hope I don’t mess up the database
Thanks again guys
Fabian
