Oh bubble community please help ![]()
I’ve set up a dynamic drop down and want to set a default value based on the available options (in the example “DefaultValue”). In the example listed what should I have for the default value.
You can leave default value blank unless you want it pre-populated with some value that you select. Otherwise it will just say what you typed in PlaceHolder - usually I type in Select a Value in Placeholder so the user knows what to do.
Ok, but in this example (with 3 entries in the table) what would I put in the default value field if I wanted to default to the “DefaultValue” value in the table. It appears I cant just type in the field “DefaultValue” as it turns red.
Ah I see…
Ok for that you need to do a database search to populate it since it’s dynamic.
It will look like the following:
In my app - I have a table called Avatars - So I search that table. You’ll see the little window on the left. Where you set what type of data you want to set. Then you can add a constraint which is a filter - here I only want to return Type = Eyes so I set that to filter the choices only to Eyes.
Last I set the default value to tell which one I want set - so I specify “first item” of the list.
This let’s my eye dropdown be pre-populated with the first eye value by default.
Hope that helps!
Exactly what I was looking for. Thank you
If John3 provided the solution to your topic, could you pls mark his comment with solved. That will help other users to see that there’s a solution available for it.
thanks
