I am having trouble with my autocomplete functionality that I set up but only on my phone (it works perfectly on the computer). Given I can’t upload a video here, I will show you a few screenshots from my screen recording from my phone
Here I have typed in the letters “Del” into my input. You can’t see it because it’s covered by the keyboard, but below it are the autocomplete results.
In the last one, you can see cursur underneath the word “Chianti”. The focus group which holds my autcomplete repeating group doesn’t stay stuck (for lack of a better term) to the input. It works fine on a computer but not on my phone.
Hi cmarchan. I have encountered the same issue as above, except my focus group is attached to a search box (so I can’t do what’s you mentioned above) and shows the results typed in the the search box input. This allows the user to use a more broader search such as area or type and the focus group will return a list of thoses users containing or matching. would you know of a work around by any chance, the app will mainly be used on phone thats all?
