Follow & Unfollow System
Hello,
Looking for help with when a user follow another member, I want that user to see user post in their dashboard. I was able to see other post in dashboard but it was for all the user. please assist if possible.
Thanks
P.s i can send like for access for a closer look…
Hi there,
Send me a link and I will have a look.
But what you will need to do is have a “Followed Users” field on your user table, which is a list of users.
Then filter your posts on where Post’s Creator is in Current User’s Followed Users.
A little like this …
Hello Nigel,
I sent link, I will try this with my app…thx
Hey Nigel,
That didn’t work for me because I am using filters so only the creator that is creating post can see in dashboard.
Yes, I saw that.
So should they see their own posts and people they follow?
yes. I would users to only see the post they create and users they are following…
I switched from filtered to adding constraint on search and it currently works. Now just trying to find out how to show post the user is following…
You can use the :merged function to add together 1) the users posts 2) the followed posts.
