I’m confused on how the page formatting works. In my design UI builder and responsive tabs some of my groups go across my whole screen and have 1080 pixels. However some groups are set to 1080 pixels and don’t go across the whole screen, I’ve tried changing the “fixed width” setting but things just don’t line-up when i change to preview my page and i haven’t found anything to help?
You might need to check the width properties for your groups. If you have the width set to 1080px but do not have fixed width checked, you group will shrink and expand its width depending on the screen width you are looking at it with. If you want the groups to be responsive, but not expand, click the “Apply a max width when the page is stretched” and set it to 100%. That should prevent the groups from expanding across the entire page.
